Hi all, sorry if this a bit long winded !
Ok - I'm going to COMPLETELY revamp my bathroom starting in 3 - 4 weeks when all the goodies are delivered by Wicks, I just have a few points I'm not 100% sure on & hope some kind sole will steer me in the right direction !
1st thing to mention is I'm NOT a plumber, BUT I am a fine limits engineer and also spent 20 years twisting wrench's as a mechanic (so general instaliation, pipework & sparks is no problem - it's system design I know nothing about !)
I'm installing a Wicks ASMARA thermo mixer shower unit (no probs on adding the 2bar brass pump & Surrey valve etc to the airing cupboard - I'm also upping the hot tank capacity to cope as I have a gravity system and want more then a 30 second shower) BUT I'm a tad unsure what I need to do to the feed pipes for the mixer unit, obviously the feeds will be sunk into the wall (internal wall is breezeblock with plasterboard over (so easy enough to chase out)) the existing bath filler pipes are @ 22mm & already just below where the shower will go (that was a stroke of luck) and luckily the new tub has the filler in the corner (old tub was in the middle) so I can tee off the originals to the new filler & extend the originals up to the shower, the bit I'm unsure on is do I need to insulate the new pipe run (within the wall) to the shower, if so with what ? (the chase will be re-plastered and tiled over), also what do I do about expansion of the copper (never sunk copper before but assume I can't just plaster it over as the expansion/contraction of the copper will obviously crack/burst any plaster that's in contact with the copper.
OR should I be using Poly for this part of the run (prefer copper if there are no major issues (Im just a oldie who believes traditional is better then new fangled stuff ))
Hope this makes sence to you
Lez (aka FriedFreddy)
