Ideal Icos boiler - gravity system - boiler locked out?
2 Oct 2010
Wiltshire
Hi
First post - hopefully someone can shed some light on the problem.
Until yesterday, everthing was fine in the domestic heating front.
Now, the boiler has no LED display. according to the manual, if there is no display - its not a boiler fault but an installation fault.
A couple of moths back, I replaced the kitchen radiators and had a similar problem, in that there was air in the boiler circuit and it would not fire. bleeding the rads and partial draining the downstairs rads solved the problem, and the boiler worked - until yesterday.
Now I thought this could be the same problem, as two downstairs radiators have no worked properly since the kitchen one were changed, so I started to bleed the rads, but no joy.
Pump is working, as is the program controller etc.
I've flushed out the condensation trap and checked the fuse on the boiler PCB.
Any idea's?
