Creaky solid wood floor
26 May 2009
London
I had the floor in my kitchen replaced with solid wood T&G boards in December of last year. This was installed as a floating floor over a chipboard subfloor. The floor has always been pretty creaky, with some visible movement underfoot in places (especially one area which has no nearby furniture).
In the past week or so I've noticed a section of the floor 4 boards wide has begun to ride up considerably as per the picture below:
If I put enough weight on the boards I can get them back down flat, although they always spring back to where they were before.
Any ideas as to what's causing this and/or what can be done?
Many thanks in advance
Simple answer: Moisture
Either moisture coming up from the sub floor, or a leak from somewhere.
If that is a big fridge freezer sitting on it, do you have leak from the back of it, or is there a blockage in the condenser area?
Find where the moisture is coming from and we can offer some more help.
The other possibility of course is that insufficient expansion has been left around the perimeter. You need to check by removing any skirting boards or trim around the edges to see if the floor itself is hitting the walls.
As the others suggested. Did you leave gaps while laying between some boards?
