DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant ecoTEC plus 824 - water fine, no heating
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
claire27
from United Kingdom
PostPosted: Wed Oct 06, 2010 4:10 pm Reply with quote
Hi
I've recently moved into a new place with an Vaillant ecoTEC plus 824, which has been providing me with hot water perfectly over the past 2 months. Now its time to turn on the central heating and I'm not getting anywhere. With the dial in either 'ON' or 'TIMER', nothing is happening- no radiator symbol on the display, no heat in the radiators, no sound from the boiler. I've tried changing the temperature- pushing it even to the maximum makes no difference.
The water is on the Warmstart system.
Am I doing something wrong, do I need to call somebody out?
Thanks for the help- much appreciated.
Claire
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 2318 times
PostPosted: Wed Oct 06, 2010 4:13 pm Reply with quote
when you turn the heating knob does the numbers change on the display?
Back to top
 Alert Moderators
claire27
from United Kingdom
PostPosted: Wed Oct 06, 2010 4:14 pm Reply with quote
Yep..
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 2318 times
PostPosted: Wed Oct 06, 2010 4:17 pm Reply with quote
have you got a thermostat on the wall somewhere?
Back to top
 Alert Moderators
claire27
from United Kingdom
PostPosted: Wed Oct 06, 2010 4:23 pm Reply with quote
I had totally forgotten about its existence (new flat easily done!)
I just moved it from zero and the boiler kicked into life...along with the radiator symbol on the display.
A million thank you's!
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 2318 times
ha lucky you didnt call someone out, would of felt a right plum icon_lol.gif
Back to top
The following user says thank you to mickyg for this useful post:
claire27 (6 Oct 2010)
 Alert Moderators
pinkbambi
from United Kingdom
PostPosted: Thu Oct 14, 2010 10:24 pm Reply with quote
hi, I have the same problem except my thermostat is set to 30 degrees and nothing!
it says the room temp is 27 so I set it to 30 so it should decide to turn on the radiators to give me the extra heat right?
no radiator symbol & no heat & my poor little baby is getting cold at night now.
Any ideas would be greatly appreciated
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2522 times
PostPosted: Fri Oct 15, 2010 12:36 pm Reply with quote
Have you set your boiler to the water AND heating position???
Tony
Back to top
 Alert Moderators
adamskie
from United Kingdom
PostPosted: Wed Nov 10, 2010 7:35 am Reply with quote
same problem here... any ideas?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vaillant Ecotec HW fine but CH not working S.30 problem 7 100 Sat Oct 15, 2011 3:03 pm
Vaillant ecomax no hot water but central heating works fine 3 1240 Thu Feb 28, 2008 3:36 pm
Vaillant VCW T3w Sine ... no hot water but CH fine ? 2 1960 Mon Oct 27, 2003 10:34 pm
vaillant ecotech 831 boiler - no CH but hot water fine 2 60 Sat Feb 11, 2012 3:26 pm
Vaillant TurboMax VUW: No hot water but CH is working fine 6 120 Sun Aug 05, 2012 2:27 pm
DIYnot
