- Joined
- 17 Apr 2005
- Messages
- 17
- Reaction score
- 0
- Country
Hi guys just found this forum and boy am i glad you are here.
I have good general diy experience more in electrics than anything else and for the first time i am embarking on some plumbing work in the home ( installing a shower ).
I have never used compression fit joints to copper pipes before and have having a lot of trouble getting them to seal.
The main problem is when i tighten up one side of an elbow all is well but when i do the other i am having difficulty keeping the pipes steady and the first join either twists loose or I bend the pipe while i am tightening up also one and a quarter turns of the 22mm nut seems alot and when i get a third or so of the way round I seem to have to put a great deal of pressure on the spanner to get further round, this is the point at which either the pipe bends or things start working loose at the other end. Is there a special spanner or method of gripping the fitting to keep all still while i tighten up.
I am using a pipe cutter and deburring. One T piece and a couple of elbows is all I am fitting into the mains water supply.
Any tips on these fittings are well appreciated thanks.
