garrymum
Joined: 16 Sep 2004 Posts: 638 Location: Leeds, United Kingdom Thanked: 4 times
Posted: Mon Oct 18, 2010 5:41 pm |
Hi guys
I need to replace a section of damaged cable outside in the garden. The damaged part is in the ground so I am going to add a junction box on the route and run a new length of cable (connecting at a new junction box). Currently the cable runs in 20mm conduit along a wall, through a 90 degree elbow, then down the wall into the ground. I would like to replace the 90 degree elbow with a junction box so I can join the cable here.
The following has a rubber gasket between the lid and box but I don't think it is suitable for exterior use, am I correct in my assumptions?
http://www.screwfix.com/prods/81094/Electrical-Supplies/Conduit/Rigid-Conduit/Terminal-Box-Angle-Black
If not, what do I need?
Thanks guys |
sparkwright
Joined: 20 Aug 2009 Posts: 3080 Location: Dorset, United Kingdom Thanked: 360 times
Posted: Mon Oct 18, 2010 6:00 pm |
You could use that, but you would need to glue the box to the conduit ends with Ega-weld. This should make it watertight. Use the gasket.
You will have limited room to do the joint in that box.
When removing the elbow, make sure you have enough length on the conduits to accept the angle box.
You can get a variety of weatherproof junction boxes that accept 20 mm fittings, but you will also require some bush ends to terminate the conduit to the box. |
RF Lighting
Joined: 31 Mar 2006 Posts: 16288 Location: Leeds, United Kingdom Thanked: 738 times
Posted: Mon Oct 18, 2010 8:33 pm |
Have you got a non armoured cable running underground at the moment? |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41722 Location: London, United Kingdom Thanked: 1352 times
Posted: Mon Oct 18, 2010 9:37 pm |
Then use one of these:
Simples. |
sparkwright
Posted: Mon Oct 18, 2010 9:42 pm |
Don't think it's armoured cable... |
ban-all-sheds
Posted: Mon Oct 18, 2010 9:47 pm |
Then it needs to be dug up and replaced with armoured.
More simples. |
