DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch Precision WFG2820
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Jim
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 25, 2010 7:48 pm Reply with quote
The machine keeps on the washing part of the cycle and wont move on to the next step. Any ideas about the problem please ?
Jim
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Tue Oct 26, 2010 6:18 am Reply with quote
Highly likely you have a heating issue....open circuit heater element, break or bad connection in heater wiring, defective heater relay on pcb, or NTC failure. Check element resistance with a multimeter first ( should be 25 - 30 ohms).
Back to top
 Alert Moderators
Jim
from United Kingdom
Thanked: 1 time
PostPosted: Tue Oct 26, 2010 4:36 pm Reply with quote
Thanks -But as it is a machine with both hot and cold water connections could it still be a heater element ? I had a look inside and found an unconnected yellow/green wire seemingly attached to the motor as the spade terminal had fallen apart. Have reattached with a new spade terminal and waiting to try machine again later today.
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 196 times
PostPosted: Tue Oct 26, 2010 8:55 pm Reply with quote
Yes it could still be a heater circuit problem.
The yellow and green wire is an earth connection
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch wahing machine Precision WGF2420 8 280 Sat May 07, 2011 3:55 pm
Bosch Precision WFG2420 - Only hot water coming in 2 540 Thu Sep 18, 2008 8:26 am
Bosch Precision Washing Machine 7 420 Sat Aug 14, 2010 5:32 pm
HELP Bosch 1200s express classixx 3 240 Wed Sep 22, 2010 7:37 pm
Aaaargh - Bosch Dishwasher will not drain again! 4 400 Mon Oct 04, 2010 9:52 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
