Worcester Junior 24i; Greenstar 25Si; or Valliant ecoTec?
1 Jul 2004
London (North)
Just wondering what's best between these?
Will the Greenstar, give me the ability to have a shower and a tap running?
Who has the best after sales?
Which is the easiest to fit?
Really appreciate all the advice guys, thanks.
Thanks,
R
your water main pressure & flow will determine if you can run a shower & tap together, experience tells me this is unlikely! as pressure fluctuation will alway occur causing temperature fluctuation in the shower, however you new combi should be sized to be able to heat the flow rate that you currently have at your property expressed in litres per minute.
I personally would go for the Vaillant Ecotec (it's a Service engineer's Boiler) - the Worcester is an installers boiler - not so easy to work on once installed! ;)
If you go a 37 cdi (greenstar ) or above you can have 2 showers at once! I personally fit loads of WB and prefer them to anything on the market ( to fit or fix) I currently have 1% failure rate in the first 5 years.
You can get a no quibble 5 year guarantee (10 yrs on heat cell) with the right installer. Would disagree about fixing wb! I suppose its what you are used to! all opinions of course!
viessmann 200 35kw. 5 years also if fitted by a trained installer also 10 year on heat ex. better to work on than the worcesters.
