DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Honeywell DT90E - how to wire up?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
akz786
from United Kingdom
PostPosted: Thu Oct 28, 2010 9:55 pm Reply with quote
Have a ariston boiler system boiler.
Drayton RTS1 room stat and a drayton Lifestyle LP112 programmer.
I want to replace the RTS1 with the honeywell DT90E - I believe the system uses a neutral to switch @240 mains also in conjunction with this lifestyle timer.
So do I need all 3 wires to new Honeywell or can I just use 2?
The DT90E supports mains and low voltage so I just want to know wats the best method of doing of this please?
PS- some posts regading this are unclear with regards to my scenario so apologies to those who have supported this issue more than once!.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri Oct 29, 2010 3:55 am Reply with quote
Just use the live in and live out . DONOT use the neutral disconnect it at both ends
Back to top
 Alert Moderators
akz786
from United Kingdom
PostPosted: Fri Oct 29, 2010 8:23 am Reply with quote
Thanks for the info, can i make the neutral at stat side"safe" and leave the other side connected, simply as i do not want to open up the junction box its all wired up too.
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 149 times
PostPosted: Fri Oct 29, 2010 8:51 am Reply with quote
Yes, put it in a connector block.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How to wire a DT90E from a Potterton EP 2000 4 220 Sat Nov 27, 2010 2:59 pm
Honeywell DT90E problems! 8 80 Sun Dec 09, 2012 11:28 am
replacing an RS1 thermostat with Honeywell DT90E 4 80 Sat Dec 08, 2012 1:29 pm
Honeywell DT90E suddenly not working 3 20 Tue Nov 12, 2013 9:08 am
Honeywell DT90E 3 120 Sat Dec 15, 2012 11:30 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
