Hello to everyone, I'm hoping for a little guidance please.
My parents have recently purchased a bungalow that needs the garage converting into a habital area. I've had 4 builders looking at it but only one has supplied a price to convert it, this i found very excessive, £10.000 in all.
I've viewed many of the threads on here and spoken to my local council for advice and sort of know what i need to do in order to achieve a nice conversion that meets BR. If i can explain the process i intend to follow perhaps as i go along i'll make very few mistakes.
I can split the conversion into 3 parts.
1. Roof
2. walls
3. floor
1. The roof, unfortunately the slope on the internal ceiling is quite excessive it falls by approx 14" from one end to the other, so i intend to have approx 3 courses brickwork to level the ceiling, hence raising the joists, allowing for a slight fall.
The BR gent advised me that a minimum of 100mm of kingspan would be required to meet current specs, this is to be applied on top of the roof boards then felted over (is this Correct) i was hoping that the kingspan could be fixed between the 4" x "2 joists. then plaster boarded plus finished.
2. The walls are single brick, i intend to apply a vapour barrier direct to the brickwork, then use 4" x 2" timbers at 450 or 600 centres then apply 100mm kingspan between the timbers, plaster board then skim.
3. The floor is concrete, i think a DPM 1200 gauge then 100mm kingspan and finally a suitable chipboard/wood floating floor finish.
There are two areas i have issues with, the kingspan on top of the boards then felted and the other is if i raise the floor by approx 118mm this creates a step up into the extension from the outside.
Can anyone advise me if they see any initial problems or offer any guidance on better materials etc.
Thankyou
Cannydanny
1. Roof
2. walls
3. floor
Thankyou
Cannydanny
