Moving Cooker Electric Switch
10 Apr 2005
I'm doing up a kitchen. The previous owners had an electric cooker, which I've replaced for a gas one. The new position of the gas cooker means that the old electric switch is right behind and above the new cooker's position. I don't need the switch. I can move it by chipping the old plaster away etc..., but would prefer to leave it where it is, and plaster over it. Is there a way to safely leave it where it is, terminate it, and make good by plastering over?
Any advice would be greatly appreciated.
Why not just replace the switch with a blanking plate, just in case you or someone else wants it in the future.
I'd quite like to tile behind the cooker and not have it there ...
disconnect the cable from the CU cover the end in adhesive lined heatshrink (just in case someone recconnects is) and then plaster straight over it.
you could also use the cable to feed a socket (with the fuse/breaker in the CU suitablly downrated) if you prefer
Sounds great - is the adhesive lined heatshrink easy to get hold of?
i think maplin sell it not sure
you need to get the heatshrink hot to make it shrink. The side of a soldering iron or a hot air paintsripping gun should be hot enough
also you should close the end with pliers or similar while it is hot.
