Hi All,
Wonder if anyone could shed any light on the following problem.
I bought a house a couple of years ago which came with a Vaillant Turbomax Plus fitted, a few months after I moved in the boiler stopped igniting, and a BG engineer came out and told me that the boiler was irrepairable due to its age, and that I should replace it with a lovely new one (to be fitted by BG).
I wasn't too keen on this, and shortly afterwards discovered that a friends brother is a central heating engineer, and he offered to take a look. He immediately diagnosed a faulty gas valve, and replaced it at a cost of £90. Nine months later the same fault occurred, and he came back and changed the gas valve again - at no cost. Now (6 months later) the gas valve has failed again, and again has been replaced for free.
I've talked to the central heating engineer who's been doing the work, and his view is that the valves are probably faulty (apparently the current parts he's getting are made by a manufacturer he doesn't trust), but he's reluctant to look any further into the problem as long as his supplier is willing to keep on replacing the knackered valves.
My question is, is there anything else that's likely to cause recurrent failure of the gas valve?, - my thinking is, that if, for example it is likely that a faulty PCB could cause this, then I'll keep my eyes peeled for a cheap 2nd hand replacement for him to install next time the gas valve dies. Incidentally, he did phone Vaillant's technical support people the last time this happened, but they were pretty useless, and basically recommended changing every conceivable part and seeing what happened.
