Well Lucia, I've learnt something new there. I had always believed that the switched live ran the fan and that when switched off, the permanent live took over and ran for the preset time - if that is not the case how does the fan get switched off in the scenario you describe?If you mean that the dimmer is used to control a light but also to activate the switched live to a timer fan: Yes it can - regardless of its setting high or low. The 'trigger' gate for a standard timer fan will activate on any impulse however low, and then the permanent live takes care of the actual running of the fan.
Lucia.
