DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting Glass
This topic originated from the How to page called Repairing a broken window - Part 2
Click here to return to the page called Repairing a broken window - Part 2.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Guest
Thanked: 0 times
PostPosted: Sun Jul 07, 2002 10:45 am    Post Subject:
Fitting Glass
Dear Sir,
I am fitting a new external stable door that has nine panes of glass. The glass is to be fitted to the door on a bed of putty from the inside of the door and then held in place by hardwood mouldings. Do I putty both sides of the glass (ie wood, putty, glass, putty, wood)or is it sufficient to fit the mouldings directly to the glass with no putty?
Thank you, Alastair Pullin.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
stevetravers
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 07, 2002 1:55 pm    Post Subject:
Re: Fitting Glass
Reply with quote Thanks
just one side .put the putty in before you put the glass in .press the glass firmly in place and finish with the mouldings held in tightly .
Back to top
 Alert Moderators
chgomike
from United States of America
Thanked: 0 times
PostPosted: Fri Aug 08, 2003 3:23 pm    Post Subject:
a neater and easier method would be the application of 1/16" black double sided foam tape to the outside stop. Make sure you "dry fit" the piece before you remove the tape strip. If it fits, you need to set the piece EXACTLY in the spot you want - if you try and move it once adhered, most likely you will have to retape the opening cause the tape will peel from the fixed stop on the door. You can buy glazing tapes through a glass company in your area - they usually won't sell to the public. The glass Co can order it for you from CR Laurence Co. THey ship UPS everywhere.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Aug 11, 2003 8:19 am    Post Subject:
I take it that this glazing tapes go on the outside of the door exposing to rain,if so is it waterproof ?
I got 90 glass panes to do !
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Sep 09, 2003 6:15 pm    Post Subject:
Info...
I have found the company that supply glazing for timber frame and very please with it. They come in all different sizes. 25m x 10mm x 3mm cost approx £6.35 + vat + delivery,not sure how much putty is but glazing tape is a lot cleaner and neat For more info see this
Back to top
 Alert Moderators
Geo-B
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 18, 2004 9:55 am    Post Subject:
A big thank you to masona for the link. This is exactly what I was looking for also. The only thing I could find was the Screwfix "E"strip which is nowhere as near the quality of this.
Cheers.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Can Glass Be Poisiness? 2 380 Mon Nov 29, 2004 9:16 am
Scratch marks on glass 4 840 Mon Aug 09, 2004 7:34 am
How do i clean grout off my glass blocks and tiles 4 1320 Fri Dec 10, 2004 2:53 pm
Glass Splashback 16 8520 Mon Jan 31, 2005 8:55 pm
Wax in Glass Vase 3 3180 Mon Mar 14, 2005 2:40 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
