DIYnot
Local | Network
   DIYnot > Forums
Local | Network
New Shower Running hot and cold
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
chrisfuz
from United Kingdom
PostPosted: Sun May 08, 2005 4:19 pm Reply with quote
I have a combi boiler and have just installed a new shower. The mixer says it is OK for combi boilers but when I use the shower it runs hot and cold. My water pressure is good. No other appliances or taps were being used while showering. icon_question.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Sun May 08, 2005 4:39 pm Reply with quote
MOre details please, on combi inc age, and mixer type?
Back to top
 Alert Moderators
PEDANTICVINDICTIVEMAN
from Western Sahara
Thanked: 1127 times
PostPosted: Mon May 09, 2005 6:10 am Reply with quote
You might end up having to run the hot basin tap to keep the boiler firing while showering during summer months.
Back to top
 Alert Moderators
xbond
from United Kingdom
PostPosted: Mon May 09, 2005 8:53 am Reply with quote
You may be exceeding your boiler's maximum flow rate, try to reduce the flow...
Back to top
 Alert Moderators
Moley
from United Kingdom
PostPosted: Mon May 09, 2005 12:20 pm Reply with quote
As you have a combi i'm guessing that you have a thermostatic mixer valve. Have you checked that the hot and cold supplies are connected the right way around? Thermostatic mixers dont like the supplies connected round the wrong way, just a thought... icon_idea.gif
Back to top
 Alert Moderators
chrisfuz
from United Kingdom
PostPosted: Thu May 12, 2005 10:24 pm Reply with quote
The Combi boiler is an Ideal CF65 or 75 I think. Don't know how old it is at least about 4 years
Shower mixer is this one.
http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=35889&id=19454
I'm sure its connected the right way round as red goes hot blue goes cold. Hard to check actual pipes as it is now plastered into the wall behind some tiles.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Fri May 13, 2005 7:15 am Reply with quote
The combi doesn't sring to mind, but the most likely source of your problem is sludge/scale in the secondary heat exchanger. They all do it eventually.
If you had your supplies reversed you would get only hot water or only coldwater, typically - at least that's what I got when I did it!
Thescale slows the temperature - sensing down so the combi turns off for long periods to get the temp down, WHen they're clean they switch on and off quickly enough that you don't notice the variation.
Not sure which type of 2ndry h/e you'll have, but they're all descalable with more or less difficulty. They have to be taken out though, as a rule.
Back to top
 Alert Moderators
from Western Sahara
Thanked: 1127 times
PostPosted: Fri May 13, 2005 7:43 pm Reply with quote
Try running the hot tap on the basin and then turn on the shower valve to approx temp position you would normally use it at, then leave it a while to stabilise and see if it solves the problem, a different shower head letting the right amount of water pass throught the boiler may sort the problem, it has on mine.
Of course if your combi is an old one and doesn't modulate, you could be up shiiitte creek without a paddle.
Back to top
 Alert Moderators
cobra
from United Kingdom
PostPosted: Fri Jul 28, 2006 12:07 am Reply with quote
Does the boiler fire when you turn on shower and does it keep cutting out and restarting- if so could be boiler thermostat cutting out due to faulty stat or scale in heat exchanger or it could possibly faulty thermostatic mixer
Back to top
 Alert Moderators
Bambi
from United Kingdom
PostPosted: Fri Jul 28, 2006 8:44 am Reply with quote
Does the water run hot and cold elsewhere, such as the bath. I had this problem and it turned out to be the heat exchanger. It was removed, cleaned and then worked OK. It could be sludged up with scale or debris from a new install. The system may need flushing too, to ensure it don't sludge up again.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Fri Jul 28, 2006 10:13 am Reply with quote
Forget it guys, this post's over a year old!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower running cold 14 1440 Tue Oct 26, 2010 5:50 pm
Thermostatic Shower running cold 12 1460 Tue Jul 21, 2009 12:54 pm
Combi-Boiler, shower mixer running Cold but all sinks are ok 4 120 Wed Jul 03, 2013 9:25 pm
Mixer shower running hot then cold 6 60 Tue Sep 13, 2011 7:56 pm
Shower running hot and cold 4 700 Mon Nov 05, 2007 11:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
