Hi All
Possibly someone can give me some info/help about my boiler as no one at Vaillant technical department has offered a response from email and when I called I was told the call out fee excluding parts would start at £275. The boiler is just over 5 years old and has worked fine for years. I think it is part of the 828 range (that is the installation manual I have for it).
Anyway I always put my boiler on timer and everyday it comes on fine. However the first day of snow it didnt. This day also just so happened to co incide with me bleeding my bathroom radiator the night before. After bleeding the radiator the pressure dropped to zero and I refilled the pressure back to 1.5. and all was working fine.
Next morning the heating did not come on with the timer. The boiler flashed F28 and pressure was down to zero. I refilled pressure to 1 this time and pressed re ignite button. Boiler lit up straight away and was fine. As well as that once it got going the boiler pressure than rose to 2.5 (the missing 1.5 of pressure seemed to come back from nowhere???).
The problem i have now is when the boiler turns off (on timer) the pressure slowly drops and boiler will not come on unless i go through the above procedure again. I now have to keep turning up and turning down the temperature at night to use the boiler, so I dont have to wake up every morning with a boiler thats flashing red.
It was cold before the 1st night of snow (dropping below zero for a few days) but the boiler was working fine on timer so I am not sure if its the cold or the fact that I bleed my bathroom radiator that seems to have created the problem. I have had no problems re igniting the boiler when it does switch off and pressure drops. And like I said the pressure always jumps up to the amount I have just added + what it was the day before once it gets heating.
Any ideas what the problem could be and what sort of cost I am looking at?
Any advice appreciated
