Been reading this thread //www.diynot.com/forums/viewtopic.php?t=253340
And im a little confused.
Is this the white pipe that comes out the condensing builers that should go to a sewage drain?
I have a issue with my boiler at the moment (heatline vizo) where the divertor valve has done wrong due to water leaking into it from a broken seal in the divertor body.
Anyway, i shut off the taps under the boiler to see what the problem is and drain the boiler, i opened the pressure realise valve in the boiler to let the water out the boiler and water (or i guess acid) came out the white plastic pipe at the same time?
(the white pipe has been disconected from a sewage drain for the time being as building work is going on, the pipe has a bucket underneath at the moment sitting on the garge floor as the garge is newly built, the boiler will be moved soon)
In all the time (3 months maybe) this pipe has been draining into the bucket i have never seen 1 drip of water come out of it?
Should i not be getting water/acid coming out of this pipe? Im not sure if its ever worked as before it went direct into the sewer so could not see.
I have checked teh pluming of it in the boiler and it is connected to a clear pot that does have liquid in it but not over flowing or draining.
