Zanussi dryer problem
Status
Not open for further replies.
10 May 2005
Hi
I have a Zanussi wjs1465w washer dryer. I have got a problem with the dryer. I had the E10 flash up during the drying cycle (and later found that the clothes hadn't dried), and checked the tap, which was fine (the wash cycle works fine). I switched it off at the plug and on again, and since then the dryer just tumbles the clothes with no heat, and the timer doesn't count down.
I would be grateful for any ideas.
E10 means water fill problem,in your case probably condenser solenoid/cold water feed
hanni0907,
I have exactly the same problem you had with your Zanussi WJS1465W washer dryer.
Did you get a solution in the end? Please don't say you bought a new machine.
I am guessing it is a defective dryer timer ( I know it has a separate timer from the washer), or some sort of thermal overload fuse. But can even find them to check, lost the book.
_______________________
moderator
17
Status
