Table lamp holder - source of the base mounting screw?
26 Dec 2010
Leicestershire
I have a broken table lamp, where the lamp holder has been snapped off the base.
Looking for a replacement lamp holder with the screw attachment at the bottom, so I can re-mount it on top of the base.
Can find hundreds of lamp-holders with varying sizes of thread in the base (1/2 inch is ideal for this application), but have failed to any sources of the actual hollow screw that attaches the holder to the lamp base.
Can anyone suggest where I can get the mounting screw?
Random photo of the type of lamp fitting I'm trying to mount, clearly showing the threaded bottom that I can't find the screw for!
http://www.angliatoolcentre.co.uk/uploads/images/products/product_32005.JPG
Jim
Your local electrical wholesalers should be able to help you out. There are small threaded bushes to reduce the size of the opening available.
It's not reducers I need (have found them), simply the actual hollow screw to bolt the thing to the base - i.e. something with a flange on one end so it can be clamped up inside the base.
Hole is about 1/2 inch, so no adjustment of size needed.
Jim
