DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Earth wire for light fitting?
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
  View previous topic :: View next topic
Author Message
Alhex
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 10, 2005 3:02 pm    Post Subject:
Reply with quote Thanks
I recently purchase a new ligtht fitting with metal frame. As all lighting circuit is old there is no earth available. Can I run an earth wire from a socket in the room above to feed the light?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 10, 2005 3:21 pm    Post Subject:
Re: Earth wire for light fitting?
best get a earth from the same circuit or take a single earth from the CU to light. altho using an earth from the sockets is better than no earth
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 10, 2005 3:45 pm    Post Subject:
Does the light need an earth? Just because it is metal that doesn't mean it does...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Alhex
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 10, 2005 6:55 pm    Post Subject:
thanks for previous reply
Yes it does need an earth it is a legal requirement. I spoke to a bloke in an electric shop and he tell me that I really should not use the same circuit as a socket to connect the earth from.
Also there is a conduit around the old wiring. The conduit should normaly be earthed. What is the best and easiest way to go about checking this out.
Thank you
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 10, 2005 7:11 pm    Post Subject:
Re: thanks for previous reply
Why do you say that?
__________________
Back to top
 Alert Moderators
Alhex
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 10, 2005 7:57 pm    Post Subject:
If there is a fault and the casing is live I could fry just changing a bulb so it would have to be earthed. I got the legal bit from a retired electrician. Any metal pendant and other need earthing
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 12, 2005 3:10 pm    Post Subject:
Earth needed ONLY if the cables in side the metal housing are not double insulated. Nowadays many are, for just that reason.
And it never was 'legal' just a very good idea.
Borrowing earths is frowned upon, as it may be removed in maintainance to the other circuit, and not realised. However, its much better than no earth at all.
__________________
regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs-
Back to top
 Alert Moderators
Alhex
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 12, 2005 4:31 pm    Post Subject:
Many thanks for all your comments.
Cheers
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu May 12, 2005 10:28 pm    Post Subject:
Seriously - check the fitting. If it says that it's double insulated, or has a symbol of two squares, one inside the other, not only does it not need an earth, it must not be earthed.
Your retired electrician friend has given you dangerously inaccurate general advice that does not apply to all metal light fittings.
If there is no indication that it is double insulated, and it has earth terminal, then yes it must be earthed.
If there is no indication that it is double insulated, and it has no earth terminal, then don't use it.
Is it new, and CE marked?
__________________
Back to top
 Alert Moderators
jtaunton
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 13, 2005 10:15 am    Post Subject:
What are the implications of trying to earth something that is double-insulated ?
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 13, 2005 10:36 am    Post Subject:
In practice it is unlikely to be a problem, but you are not using it as the makers intended, so guarantees are affected, and it may no longer pass the flash test of the insulation that makers would have performed to certify as double insulated. However, that alone does not make it any more dangerous than it was before.
If making up fittings for home use, I'd recommend double insulated construction plus earth.
The most dangerous thing is to think you have earthed it, but to have connected to an earth that doesn't actually go back to true earth - in old lighting circuits this can occur. The floating wire can then pick up a voltage by capacitive couling to adjacent wiring, causing all sorts of unpleasantness. So having got an earth, using a meter on ohms and a long wander lead, make sure it really does connect back to the board.
__________________
regards Mike(G7VZY)
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 17, 2005 11:15 am    Post Subject:
I think it does. A 100% earth-free environment is the safest there is. We have earthing, and bonding, because this is very difficult to arrange in practice, so protection from indirect contact becomes essential. But earthing something unnecessarily just introduces more earths into an environment, and so lowers overall safety.
Consider this concept: Would you feel more, or less, safe if you had a cable permanently running between your body and your MET?
If less, then you should also feel less safe the more earthed metal there is in your environment....
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Light fitting - earth wire 2 760 Wed Jan 09, 2008 1:37 pm
fitting a wire system to a lighting circuit not ring main? 10 480 Mon May 05, 2008 9:15 pm
Outside light without an earth wire? 3 160 Sun Oct 04, 2009 2:27 pm
Light switch - Earth wire 9 300 Thu Apr 09, 2009 11:28 am
Ceiling Light with no earth wire 11 1900 Mon Nov 17, 2003 9:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
