wher to buy mono mixer taps with 210mm gap between holes
2 Feb 2006
im looking to change the basin and pedestal in the bathroom and iv seen a nice one on sale near me, the problem is the basin has two tap holes for the taps, that not a problem but I require a mixer tap- sadly the taps holes distance is 210mm from the centre of each hole and ive had a look on the net and I cant see any for sale with such a large width. The max I’ve seen is 180mm length.
Would anyone advise as to where I can buy a mixer tap set with 210mm gap between the taps (for sensible money) or is this size not made.
btw if anyone thinking whey not buy another type of pedestal its because the carpet is fairy new and don’t want a large hole around the new basin- nothing like doing thing in the right order is there :oops: - the one ie seen on sale overcomes this
many thanks
Never come across a mixer with these centres, 180mm is the UK standard. If you want a basin mixer tap the normal route is to buy a basin with one tap hole, as these will accept a standard mixer
Hi
The problem is my old pedestal is quite wide at the back (220mm) and then slims down towards the front (like a triangle shape) from what ive seen on ebay the newer pedestal seems more straight at the back thus I will have and area where there is no carpet if it was not for the carpet I would have brought and pedestal with single mixer by no- if only it was so simple :D
