Outdoor lights at front door/garden
28 Apr 2010
Avon
I'm looking to wire in some lighting outside at the front of my house. The first will be a 20w PR light next to my door - do I spur an FCU from my downstairs light circuit (using 1.5mm) and run a cable straight through the wall into the rear of the light and so not revealing any cable externally?
Next, I want to setup some lights around the front garden, low power (most likely LED) just to make the garden look a little prettier, these will most likely be ground embedded cabling - whats the best way to hook these up? Mains or lighting circuit and via an FCU?
My CU is RCD protected.
Appreciate your help!
If the PR light manufacturers instructions ask for an FCU then yes - and you would probably use a switched 3Amp FCU. But you could just run 1mm T&E from the nearest ceiling rose line and neutral loop through a switch and onto your wall light.
You will need steel wire armoured cable if you intend to bury cable in the garden linked back to the Consumer unit or spurred from another household circuit. I'm also pretty certain that you will need to inform your Local Authority Building Control and pay their fee before proceeding - unless you employ an electrician who is deemed competent to sign their own work off.
What you're proposing for the garden could work out quite expensive to make the garden prettier - might be better and cheaper to buy some extra plants ;)
How many lights are already on your circuit?
A kit of low voltage lights and transformer, plugged into a 13A socket.
It's safe and effective and easily DIYable.
And a cheap, nasty, shoddy, amateurish bodge.
If using ELV lights as the OP suggests, I would be more inclined to a weatherproof enclosure outside with a bank of outlets controlled by switches inside the house, but that may be because of the layout of my house and garden.
//www.diynot.com/wiki/electrics:voltage-bands
Ooops, do beg pardon. :oops:
Extra Low Voltage lights.
How do you know he has an outside socket?
Transformer and mains plug inside. Only ELV wiring outside.
Sorry for the late reply, I know it has been a while but this challenge still awaits and I appreciate all of the responses.
This solution, as you say, is simply, easy and I assume won't require me to seek permission from the council? In addition, can such lighting kits have their wiring buried without additional shielding??
Ban-all-sheds, I fully appreciate what you're saying and if I had the time/money I would prefer an external electrics housing box, primarily because it would open up the ability to expand the outdoor electrics in the future more easily, but I haven't the time...nor the money unfortunately :confused:
Outdoor lighting is notifiable.
No.
I suppose that is probably strictly all true, but have to say that, in relation to ELV wiring..... !!! Some degree of mechanical protection (even if only hosepipe) for any buried ELV wiring would make sense but, again, beyond that ......!!!!
Kind Regards, John.
I might have misunderstood but doesn't your above reply contradict a response you gave to someone else on this subject?
There's no requirement for them to be ELV.
Para 3© of Schedule 2B exempts "pre-fabricated equipment sets and associated flexible leads with integral plug and socket connections."
So if you buy a pre-assembled lighting set with a plug on it it's exempt. If you roll your own from lights, cable and a plug it's notifiable.
So now I'm confused - I believed that if I bought a pre-wired lighting set from B&Q for instance, with a transformer plugged into a socket inside the house, it wouldn't be notifiable?
Based on your above reply to another user, I can choose any pre-wired outdoor wiring kit, regarding of voltage/ELV? And I would assume that such pre-wired kits might support buring the wiring.
