DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Earthing question
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Author Message
skymatt
from United Kingdom
PostPosted: Mon May 16, 2005 12:18 pm Reply with quote
I am currently at the tail end of moderising my house. I have now realised that the light switches / hanging lights are all metal but have no proper earthing.
I do not really want to replace all the lighting rings as the house is in a near finished. I have worked out that I could run earthing cable for all the light switches and 75% of the lighting roses (The rest I could replace with plastic roses) via some chasing of the walls and lifting the floor boards back to the consumer unit. Which would minimise the mess
Is this a viable option?
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 14 times
PostPosted: Mon May 16, 2005 3:01 pm Reply with quote
not modernised then. If a jobs got to be done its worth doing correctly. I hear you say that will be ok, and yes it will utill you are unfortunate enough to have a fault condition introduced.
Back to top
 Alert Moderators
skymatt
from United Kingdom
PostPosted: Mon May 16, 2005 3:06 pm Reply with quote
What exactly due you mean by a fault condition introduced?
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 1 time
PostPosted: Mon May 16, 2005 4:22 pm Reply with quote
Skymat, replacing accessories with plastic does not remove the need for the cable to incorporate an Earth.
The whole lighting circuit, and probably the Ring main needs to be rewired. This may not be what you wanted to hear, but this is the situation you are faced with.
The cpc (Earth) in a cable has two roles.
1: It protects the users of an installation from dangerous currents under fault conditions and removes them to ground, causing protective devices to operate thus disconnecting the supply.
2: It protects the cables from external influences that would otherwise go undetected and could lead to a fatal shock or fire as no earth path means that no automatic disconnection of the supply can occur.
With respect, if you do not understand the real need for cables to incorporate a cpc, then you should not do this work yourself and should at least consider calling in a professional.
Back to top
 Alert Moderators
skymatt
from United Kingdom
PostPosted: Mon May 16, 2005 4:30 pm Reply with quote
FWL_Engineer
I hear what you are saying. The ring main is in good order and I have had that checked out as a new CU was installed.
With the lighting circuits if I ran earthing cable to 100% of the roses and switches would this be okay? And I except this would not be as good as a re wire but would it still do the job?
Back to top
 Alert Moderators
keyplayer
from United Kingdom
Thanked: 20 times
PostPosted: Mon May 16, 2005 4:36 pm Reply with quote
How is this easier than a rewire??
Back to top
 Alert Moderators
kendor
from United Kingdom
PostPosted: Tue May 17, 2005 1:35 pm Reply with quote
you could stick an isolation transformer on every lighting outlet.
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 17, 2005 2:26 pm Reply with quote
As everyone posting here knows, lots of houses still have a missing earth in the lighting circuit. Nowadays it is quite common to buy electrical equipment which is 'double insulated'. In other words, designed to work without an earth and supplied with a mains cable having only two cores. I mention this to demonstrate that an earth is not always essential.
So it rather depends whether your lighting accessories are also designed to work without an earth.
Current regulations specify an earth on lighting circuits. they also specify lots of other things which are likely to be missing from your house and many other houses. Even some rewired in the last few years. Regulations change all the time. It does not mean that everything has to be ripped out and replaced each time they are revised. Which would probably be every year.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1899 times
PostPosted: Tue May 17, 2005 3:26 pm Reply with quote
In the light (sorry) of what you did not do with the electrical system, would you care to rephrase that?
Back to top
 Alert Moderators
skymatt
from United Kingdom
PostPosted: Wed May 18, 2005 3:16 pm Reply with quote
I have seen the light icon_idea.gif ( Bad joke I know) I have spent a year doing all the work and just was not expecting the lighting issue. I now plan to spend this weekend re wiring the lighting circuits with two mates who are electricans. (Paying for there time in beer).
Yet another lesson learnt if I am every mad enougth to do up another house icon_rolleyes.gif
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 1 time
PostPosted: Wed May 18, 2005 6:43 pm Reply with quote
Skymatt, good decision there and nice to see that someone does listen to advice when given by several people.
Good luck over the weekend, at leats when this is complete there will be "light at the end of the tunnel" for the refurb of the house. (Sorry, just thought I would get in on the bad puns icon_biggrin.gif)
Back to top
 Alert Moderators
bpowell555
from United Kingdom
PostPosted: Fri May 20, 2005 10:11 am Reply with quote
Handy couple of mates!
Back to top
 Alert Moderators
skymatt
from United Kingdom
PostPosted: Tue May 24, 2005 12:51 pm Reply with quote
All done. A very hard weekends work and some finishing plastering to be done. But now much happier icon_lol.gif that the lighting rings are all new and earthed. I even have a light in my loft!
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Tue May 24, 2005 12:56 pm Reply with quote
wot no bad head icon_question.gif icon_question.gif icon_question.gif icon_wink.gif
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
question on TN-S earthing 14 640 Sun Dec 14, 2008 7:26 pm
not another earthing question 13 860 Mon Dec 06, 2004 11:10 pm
Part P Question and Earthing Issues ? 6 760 Sun Dec 30, 2007 11:16 pm
Earthing question for isolator board 3 280 Wed Mar 24, 2010 6:46 pm
Earthing question again!!! 7 800 Thu Oct 14, 2004 5:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
