DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Bosch Greenstar 24i Junior Problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
chrisdicko
from United Kingdom
PostPosted: Sat Jan 22, 2011 12:00 pm Reply with quote
Hi all,
I had a new Worcester Bosch Greenstar 24i Junior boiler fitted in Nov 2008, and is now out of warranty unfortunately.
The problem is, it doesn't always fire up, and is quite random when it doesn't. Sometimes it will work all day, every time, and other days it will be really intermittent.
When the hot tap is turned on, it doesn't fire up, so cold water comes out of it, also I have my heating on all the time, and controlled of the thermostat. But it still doesn't come on when it should be. (it isn't the thermostat).
I find turning to power off to the boiler for 10 minutes normally helps, but no always.
Any idea what the problem could be?
I phone Worcester, but it is going to cost £215 for them to come out to me, which seems quite a lot!
Any advice would be great.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 789 times
PostPosted: Sat Jan 22, 2011 12:07 pm Reply with quote
Get a local guy in to have a look.
Back to top
 Alert Moderators
Tibbot
from United Kingdom
Thanked: 224 times
PostPosted: Sat Jan 22, 2011 12:16 pm Reply with quote
This boiler is very difficult to work on, especially the hydraulic parts, which your intermittant fault could well relate to. The Worcester repair may well prove quickest, most effective and cheapest. If it hasn't been serviced annually then you won't have yet spent anything on maintenance.
Back to top
 Alert Moderators
chrisdicko
from United Kingdom
PostPosted: Mon Jan 24, 2011 12:33 pm Reply with quote
I phoned Worcester and they said £215 to come out and repair.
Is this an OK price?
Back to top
 Alert Moderators
MIGEM
from United Kingdom
Thanked: 14 times
PostPosted: Mon Jan 24, 2011 2:30 pm Reply with quote
Get a local guy to check your water pressure switch.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2573 times
PostPosted: Mon Jan 24, 2011 2:39 pm Reply with quote
When it does not fire up what indication of the problem do you get ion the front?
I suppose that you did not get it serviced at the end of the first and second years?
It may be a simple ignition setting that would be dealt with on a service.
Tony
Back to top
 Alert Moderators
chrisdicko
from United Kingdom
PostPosted: Tue Jan 25, 2011 3:23 pm Reply with quote
No, Stupidly I forgot about it....as it was working fine for two years.
There is no indication as such, just the boiler doesn't light up, and the green LED doesn't light up.
This morning when I got in from work it wouldn't start up at all. The pressure was up to 2.5 bar which it hasn't been filled up to that ever before, and the water definitely passing the valves.
I emptied a bit of water out via the radiators, and it went down to 1.5 bar, I turned the power to the boiler back on, and everything worked fine.
Just got up now (I'm on nights) and the pressure was at 1.5 bar still, but the heating should have been on, but it wasn't. I ran the hot tap and it still didn't ignite, but as I was stood there the pressure raised to 2.5 bar in front of my eyes.
Does this sound like an obvious problem?
I'm going to set up a service contract, with some like British Gas, but will I need to get the boiler repaired before I do this? Or might they fix it on the service?
Back to top
 Alert Moderators
chrisdicko
from United Kingdom
PostPosted: Tue Feb 08, 2011 4:33 pm Reply with quote
Just to bump this back up.
The boiler finally stopped working yesterday, and would sound like it was firing up, but then just went off.
The engineer has been round today, and said it is the pump. It is getting power to it, but isn't spinning as it should. So he wants to fit a new one tomorrow when he gets one.
Do you normally replace these, or would you normally fix them?
Back to top
 Alert Moderators
skipdip
from United Kingdom
PostPosted: Tue Mar 01, 2011 8:39 am Reply with quote
Hi there everyone, i am intrigued to find out if the new pump solved your problem as i am experiencing a similar problem with the same boiler in a barn i converted a while a go now but never seems to have worked properly, the boiler is now out of warranty and am wondering whether to go down the same route as yourself.
Cheers
Al
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Bosch Greenstar 28i Junior Problems 12 7060 Wed Dec 29, 2010 6:57 pm
Worcester Bosch Greenstar Junior 28I 5 1900 Mon Nov 05, 2007 8:08 am
Worcester Bosch Greenstar 28i Junior boiler 5 360 Fri Sep 23, 2011 7:06 pm
Worcester bosch greenstar 24i junior filling key stuck 3 140 Thu Feb 02, 2012 1:45 pm
Bosch Worcester Greenstar 24I junior 4 4920 Mon Sep 17, 2007 8:45 pm
DIYnot
