DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wylex fuses
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
tuppa
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:15 pm    Post Subject:
Wylex fuses
Reply with quote Thanks
I have a consumer unit in my house that takes a combination of NSC 15, NSC 30, NSC 05 circuit breakers.
If possible I would like to swap these circuit breakers for the \\\"Trip type\\\" of breakers instead of the little fuse type I have.
What type do I need? Will anyone\\\'s breakers fit? Can you sell me them if they have to be wylex?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:21 pm    Post Subject:
ne chance of a pic? would help us a lot more to say wether you can use em or not
if you can use them, then all you need is the breakers and they should just swap for a fuse
Back to top
 Alert Moderators
tuppa
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:37 pm    Post Subject:
Wylex fuses
I have some photos but cant manage to get them posted!
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:39 pm    Post Subject:
Re: Wylex fuses
you have to us an image hosting site and put the link on here
Back to top
 Alert Moderators
tuppa
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:40 pm    Post Subject:
Wylex fuses
Sorry you have lost me off with that, can I send????
Back to top
 Alert Moderators
tuppa
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 20, 2005 8:42 pm    Post Subject:
Wylex fuses
Got the idea!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri May 20, 2005 9:36 pm    Post Subject:
in therory you should be able to replace those with wylex nsb series breakers.
unfortunately in practice different ages of wylex part have slightly different bussbar hights even though they have the same part number! so you may have to bend the bussbar slightly to make everything fit.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri May 20, 2005 9:37 pm    Post Subject:
Why do you want to replace them? Do they blow very often?
Some good advice:- stay with fuses for the lighting circuits, or the first time a bulb fails you will rue the day you swapped to MCBs....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 1:02 am    Post Subject:
They are cartidge fuses, with RCD you have should be pretty reliable. If your having to change often i suspect you have a problem with overloading.
NSB mcbs should change straight over (looking at it looks like it may even be the B type breakers ie B5 = 5amp
Go to their website, you can ask them online
www.electrium.co.uk
Back to top
 Alert Moderators
tuppa
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 6:34 am    Post Subject:
Wylex fuses
they dont blow very often at all, but no where locally to me carries these fuses and it would also be easier for my wife to flick the switches if I happen to be away or at work.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wylex fuses. 4 540 Tue May 29, 2007 12:52 pm
Replacing wired fuses (Wylex) with MCBs 22 1440 Sun Mar 09, 2008 3:15 pm
Old Wylex fuses - Help!! Update ***Sorted :)*** 15 780 Sun May 04, 2008 1:44 pm
Are Wylex C. U.'s with rewireable fuses still legal? 6 360 Sat May 30, 2009 8:31 pm
Wylex Fuses 4 1540 Sat Feb 26, 2005 12:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
