DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bathroom connections
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
pilgrim1
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 8:31 am    Post Subject:
Reply with quote Thanks
I'm about to add some mains to power (from a spur off the lighting circuit) for an above mirror light (Low voltage). I was going to drop the transformer into the ceiling void, however I now I now find the mirror will arrive some weeks after I need to plaster and tile. I’m thinking now of channelling the mains cable into the wall and then connecting the transformer to this at a later date. What is the best (legal icon_cool.gif ) way to do this? I’m thinking of putting an electrical mounting box with a closed facia and make the connection internally when the mirror unit arrives.
Thanks in advance.
ChrisC.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 11:34 am    Post Subject:
Have you considered part P ?
Back to top
 Alert Moderators
pilgrim1
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 6:18 pm    Post Subject:
Yep, my sparky is on holiday in Spain at the moment icon_sad.gif he will be inspecting and signing it off. However the room will be plastered before he gets back, which was not in the plan. Hence the question here, I don't plan to plaster and then rip it all up again. So any more helpful advice would be appreciated.
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 6:52 pm    Post Subject:
can you not put cable in now, then put transformer in the ceiling void from above
Back to top
 Alert Moderators
pilgrim1
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 21, 2005 10:37 pm    Post Subject:
Sadly not. icon_sad.gif the sparky is providing the transformer and lights. The plasterer was due to come after the electrician, however he has now had do it earlier. So I’m stuck with having to add the mains and get the electrician to connect up to that.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun May 22, 2005 9:39 am    Post Subject:
Not in terms of certifying compliance with the building regulations, as he's not done the work.
This may not bother you, but I always feel that breaking the law should be an informed decision, not a blunder brought about by ignorance...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
pilgrim1
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 22, 2005 11:14 am    Post Subject:
Can I ask what on earth (no pun intended) does this answer have to do with my question? Did you even read my question? Simple as this this. I need to get out of a scrape. Maybe it's no hasstle to you that I'll spend a fortune on plastering my walls to rip them all up again to lay one cable. It's not rocket science taking a 3 core cable from a junction box, 3 feet down a wall (assuming the cable supports the appropriate Ampage of course) A monkey with the right cable some sense of colour and a screwdriver is able to do so. As it happens what I was asking is simply what is the best way to terminate it, so my electrician can make a further connection at a later date? I don't need a team of lawyers to watch me install it. I need someone who thinks, yep I've had the same problem, do this, it will be fine and the electrician won't have a heart attack when he returns and rip up all my plaster and do it again. Having not encountered this problem before I assumed someone here would help. Wrong. As for the electrician not signing it of, he will simply meter it out and say...my god man! You've wired three coloured wires from three identically coloured wires in a junction box correctly! And without a team of inspectors! How is it possible? And you merely a electronics engineer.
Anyway, I thank eveyone for all the legal advice. I go to a legal site now and see if they know anything about household electrics.
CC
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 22, 2005 11:37 am    Post Subject:
he was tryin to say that your spark can only sign of work that was done by him, and him only. he cant sign off your work. only BC can sign off your work
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Kitchen wiring: Ring, spur & fused connections 12 1140 Fri Jan 27, 2006 3:24 pm
dimmer switch connections 5 460 Fri Feb 17, 2006 1:40 pm
connections behind radiator 12 600 Wed Dec 28, 2005 8:09 pm
Using a light switch to make connections 4 480 Mon Oct 03, 2005 8:31 pm
ceiling rose connections 3 2280 Thu Sep 08, 2005 7:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
