DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hotpoint FDW60 not draining
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
peterrenfrew
from United Kingdom
PostPosted: Wed Feb 16, 2011 7:09 pm Reply with quote
It works fine until it comes to the drain cycle then nothing, no sound even. It will drain manually - it's not blocked. No warning lights, controls work as normal. Have tried tilting it, disconnecting from supply. If I drain manually it works fine again till drain part of cycle. Anyone help please?
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1005 times
PostPosted: Wed Feb 16, 2011 7:47 pm Reply with quote
Have you taken of the drain pump and checked the impellor. If it's jammed it will still drain but no noise.
Back to top
The following user says thank you to rocks1 for this useful post:
peterrenfrew (16 Feb 2011)
 Alert Moderators
peterrenfrew
from United Kingdom
PostPosted: Wed Feb 16, 2011 9:12 pm Reply with quote
I checked the drain pump, found the electric cable had come off, replaced it, started up again. Now the drain pump seems to run but it doesn't fill up now! Eco green light flashes
Back to top
 Alert Moderators
rocks1
Thanked: 1005 times
PostPosted: Wed Feb 16, 2011 9:33 pm Reply with quote
Now you have water in the base. Tip it forward with some towels check what u did cos it's now leaking. Poss from the pump , did u put O ring back on the pump face.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint dishwasher FDW60 not draining 2 2340 Sat Aug 04, 2007 2:04 pm
hotpoint aquarius fdw60 dishwasher not draining.....help.... 2 1260 Tue Oct 12, 2010 11:57 am
Hotpoint FDW60 lights 3&4 Flashing 2 80 Wed Jan 18, 2012 1:51 pm
hotpoint fdw60 fault 18 340 Mon Feb 06, 2012 7:13 pm
HOTPOINT FDW60 - STOPPED WORKING 2 60 Sat Dec 17, 2011 9:53 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
