DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cooker hood
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
yellow
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 30, 2005 11:19 pm    Post Subject:
cooker hood
Reply with quote Thanks
i am installing a new ring in my kitchen, there is going to be a cooker hood fitted aswell, i have put a single socket outlet high up( in the ring) to enable me to fit a plug on the end of the hood flex and then just plug the hood in.Would this be exceptable..
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
comms
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 8:01 am    Post Subject:
Yes.
you could use a switched fused connection unit instead of a socket.
Back to top
 Alert Moderators
rcman
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 2:53 pm    Post Subject:
I dont wish to "hijack" this post, but my question was very similar - I have both an extractor and a gas hob to plug in. Can I put a plug on the extractor and then plug that and the gas hob via a double adaptor into the socket on my cooker switch panel?
Messy, I know, but at the moment my cooker switch is at the back of a wall unit (which is another issue, maybe) so won't show too much.
Is this all safe/within regs? What about heat from the built-under oven on the cable from the gas hob? any prcautions I should take there?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue May 31, 2005 3:47 pm    Post Subject:
the oven shouldnt give off that much heat behind it. main issue is gas hob near a plastic flex. it will look a mess. best really to find a ring main and extend it, fit 2 sockets, one high, one low.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Cooker Hood Rating 7 400 Mon Jan 16, 2006 4:35 pm
cooker hood fitting quote 13 1240 Fri Sep 19, 2008 2:59 pm
cooker hood/extractor and 40a mains spur 2 160 Tue Sep 16, 2008 9:43 am
cooker hood 2 140 Wed Sep 10, 2008 10:11 am
cooker hood 3 140 Tue Sep 23, 2008 2:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
