DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How do I disconnect a burglar alarm sensor?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
markjg123
from United Kingdom
PostPosted: Wed Mar 09, 2011 7:29 pm Reply with quote
I need to permanently remove a wired sensor from my Veritas R8 alarm system. The sensor I want to disconnect is spurred from another sensor. Can anyone advise on how to do this?
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Thu Mar 10, 2011 1:28 am Reply with quote
Carefully, is the first answer.
Have you the engineering code?
Without this the panel will activate and go into alarm.
It might be programmed for user reset.
Take detector apart or lift the lid on the panel and then refit and use your code. If it resets your in luck. If not you need an engineer to assist.
Back to top
The following user says thank you to Alarm for this useful post:
markjg123 (10 Mar 2011)
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Thu Mar 10, 2011 9:03 am Reply with quote
The only code I have is the user PIN to set/reset the system. The system was installed before I moved in and I wasn't left any documentation. Clearly I should have asked the previous owner who the installer was. This may be a very dumb question but if I manage to find a local engineer how will he know the engineer code? Is this a specific code known only to registered installers or could it have been set by the installer?
Back to top
 Alert Moderators
mryoung
from United Kingdom
Thanked: 46 times
PostPosted: Thu Mar 10, 2011 12:36 pm Reply with quote
He wont know the code as this is specific to the installer, it may even still be set to default but this is unlikely.
Any engineer worth his salt can reset the code to default for you.
Back to top
The following user says thank you to mryoung for this useful post:
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Thu Mar 10, 2011 3:20 pm Reply with quote
As Mr Y says.
For local assistance use these leads.
http://www.ssaib.co.uk/
Or
http://www.nsi.org.uk/
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Thu Mar 10, 2011 3:23 pm Reply with quote
Sorry for the poor spelling of assistance.
It seems this will not let me edit.
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Thu Mar 10, 2011 3:24 pm Reply with quote
Now it does!!!!!!!!
Back to top
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Fri Mar 11, 2011 12:28 pm Reply with quote
OK. I've taken the front panel off the 2 sensors and the wiring is very different. I've attached photos. The first is the sensor I want to keep. The second is the one I want to remove. The 'surplus wiring' from the sensor I want to remove is just tucked behind the one I want to keep.
So what do I do now?
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Fri Mar 11, 2011 3:36 pm Reply with quote
The first one is fitted incorrectly.
The second is correct.
REd and Black being the power.
Alarm is Blue/Yellow.
Tamper Green and White.
Drop the green and white into the spare terimnals of the first pir. As it is "back to back".
Back to top
markjg123 (11 Mar 2011)
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Fri Mar 11, 2011 5:44 pm Reply with quote
OK. Can you explain why the first one has a twisted pair of red and black wires? Do I need to do anything with them?
Once I've connected the green and white to the first PIR, am I good to completely remove the second one?
Back to top
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Fri Mar 11, 2011 7:43 pm Reply with quote
Both PIRs are supplied by an eight core wire - red/black/blue/yellow/green/white/orange/brown.
The PIR I want to keep is connected directly to the control panel. It has red/black/blue/yellow connected to terminals as shown. The green/white wires are not connected to anything. The brown wire is connected to the yellow wire (using insulation tape) that runs to the other PIR. The orange wire is connected to the blue wire (using insulation tape) that runs to the other PIR.
The PIR I want to remove is the one with the orange/brown wires on show but are not connected to any terminals. It has red/black connected to red/black in the PIR I want to keep. The green/white/orange/brown wires are not connected to anything even though green/white are connected to terminals in the PIR. The yellow/blue wires are connected as described above.
Can you please decipher for me and explain how to (a) disconnect the PIR I want to remove and (b) correctly wire the PIR I want to keep?
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Fri Mar 11, 2011 7:53 pm Reply with quote
The twisted pair are the power.
The others are alarm and tamper.
It even tells you on the board/PCB in the detectors which is which.
Back to top
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Fri Mar 11, 2011 8:21 pm Reply with quote
Sorry, I worked out that much.
I can't figure out why:
1) The tamper wires from the panel are not connected to the PIR I want to keep.
2) One end of the tamper wires from the spur cable are connected to PIR I want to remove but the other end is not connected to anything.
3) The alarm wires from the spur cable are connected to orange/brown from the panel cable.
Do I stop worrying about this and simply:
A) Disconnect the power wires in the spur cable from the PIR I am keeping.
B) Disconnect the alarm wires from the spur cable that are connected to orange/brown from the panel cable.
C) Connect the tamper wires from the panel cable to the PIR I want to keep.
I assume brown/orange are not required.
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Fri Mar 11, 2011 9:14 pm Reply with quote
Without looking and tracing all cables back.
It would be difficult to comment correctly.
But to answer as much as I can.
1,sloppy fitting.
2,See above.
3,Joints somewhere, hence the "series" fitting.
A, drop them the pir will stop working.
B,take them out see what happens. My guess is you will lose a circuit and the panel will not set.
C,Deffo keep the tamper, as you never know!
I assume the brown are needed, as its been fitted back to back. You will need to close that circuit off.
Back to top
 Alert Moderators
markjg123
from United Kingdom
PostPosted: Sat Mar 12, 2011 11:46 am Reply with quote
All sorted!
Have completely removed the unwanted PIR and it's wiring.
Have connected the tamper wires on the PIR I kept - all the other PIRs in the house have been connected in this way.
Have completed a walk test and all is fine.
I initially got a zone open fault on the walk test for the zone where I'd removed the PIR. This was rectified once I joined brown/orange.
Thanks very much for all your help.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
how do i disconnect my burglar alarm? 15 7860 Mon Aug 03, 2009 11:59 am
Disconnect Alarm from telephone system / ADSL filtering 9 300 Mon Nov 28, 2011 1:59 pm
Van alarm disconnect 3 80 Fri Dec 09, 2011 11:27 pm
Temporarily disconnect Veritas 8 control panel to plaster 10 120 Thu May 10, 2012 12:41 pm
Disconnect external siren Scantronic 500 r 3 700 Fri Mar 20, 2009 8:22 pm
DIYnot
