DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Boiler coming on when programmer is off?!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
remlap3
from United Kingdom
PostPosted: Fri Mar 11, 2011 2:15 pm Reply with quote
Hi there people,
I have a problem with my boiler where it still comes on even though the programmer is switched off. The thermostat still controls whether it comes on or off, but it still comes on when the programmer is set to off.
Although, when the programmer is due to come on (at certain time) this still works and the boiler fires up as normal.
I have gravity fed Potterton boiler. Any ideas or suggestions would be most grateful!
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 11, 2011 2:29 pm Reply with quote
what motorised valves do you have ?
1 x 3 port or 2 x 2 ports ?
sounds like you have two seperate valves and the heating one is sticking.
Back to top
 Alert Moderators
remlap3
from United Kingdom
PostPosted: Fri Mar 11, 2011 2:33 pm Reply with quote
how would i check that? i'm a bit of a novice I'm afraid...
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 11, 2011 2:36 pm Reply with quote
have you 2 of theses.
or 1 of these
does the room stat still control it when its firing up with the programmer off ?
Back to top
 Alert Moderators
remlap3
from United Kingdom
PostPosted: Fri Mar 11, 2011 2:40 pm Reply with quote
I will have a look when I get in, would these be inside the boiler? Or somewhere else?
Yes the thermostat still controls the boiler when the programmer is switched off.
Thanks for your help
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 11, 2011 2:43 pm Reply with quote
so if programmer off
then the boiler fires up and you turn room stat down the boiler will stop ?
Back to top
 Alert Moderators
remlap3
from United Kingdom
PostPosted: Fri Mar 11, 2011 2:46 pm Reply with quote
yes
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 11, 2011 2:52 pm Reply with quote
sounds like the programmer is still giving out a live to the room stat when it should be off.
you need to locate the live to the room stat from the programmer heating on and test with a multi meter.
if live when programmer off programmer is faulty.
Back to top
 Alert Moderators
remlap3
from United Kingdom
PostPosted: Sat Mar 12, 2011 2:29 pm Reply with quote
I had a look in the airing cupboard last night and we have 1 of the bottom images (so not 2 of the other one). Does that help??
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Boiler Coming On, Programmer Off 3 240 Sun Sep 07, 2008 8:26 pm
CH coming on with HW even though set off on programmer 2 140 Tue Jun 30, 2009 7:41 pm
ravenheat boiler not coming on in ch mode 3 720 Fri Dec 08, 2006 6:26 pm
HELP - Boiler keeps turning itself off & not coming back 19 5180 Tue Jan 24, 2006 3:35 pm
Vaillant ThermoCompact boiler - seems to keep coming on 6 480 Wed Aug 04, 2010 2:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
