DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Jigsaw Tile Blades - Useless On Porcelain Tiles?
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling
Author Message
RealPolitik
from United Kingdom
PostPosted: Mon Mar 14, 2011 12:30 am Reply with quote
I've bought some jigsaw tile blades from Wickes (I know ... ) as I have a few door frames with odd skirting to tile around and it's very difficult to be precise enough with the wet cutter.
I'm trying to cut porcelain floor tiles and it's impossible - after thirty seconds the blade has barely made an impression.
Am I expecting too much from them - are they only any use on thinner wall tiles?
Back to top
 Alert Moderators
sherlockholmes
from United Kingdom
Thanked: 7 times
PostPosted: Mon Mar 14, 2011 12:29 pm Reply with quote
"For use on ceramic tiles, roof tiles, slate, fibreglass and plastic"
From the website, no mention of porcelain tiles and since you've already found they don't work that seems fairly conclusive on it's own.
I looked into this question recently in prep for some diy tiling, i'll share the fruits of my labours with you - it can only really be done by something with a diamond blade and a helluva lot of torque, like a mini angle grinder or the wet saw. With the wet saw you can cut the bulk out as a triangle then nibble with straight cuts and finish with a tile nibbler. With the angle grinder you can actually cut a curve, though it's a skill that looks to require a little practice and they aren't the safest of tools if you aren't used to them. There are loads of videos up on youtube of folks angle grinding porcelain tiles if you want to give it a go. That's the method I plan on trying when I get round to it.
If you have a lot of curves that will be on display and want a very neat finish though, you may want to consider getting an experienced tiler to do it. They're generally fine if you get recommendations/references, have no kids or pets in the house, and keep them placated with a constant supply of very sweet tea. Some keepers recommend occasional feedings with some kind of chocolate covered biscuit too.
Back to top
 Alert Moderators
1john
from United Kingdom
Thanked: 336 times
PostPosted: Mon Mar 14, 2011 2:20 pm Reply with quote
Cut the bottom of the architrave off and slip the tile underneath. Allow the height of the tile and addy plus a millimeter or two.
Back to top
 Alert Moderators
paul78
from United Kingdom
Thanked: 24 times
PostPosted: Mon Mar 14, 2011 7:59 pm Reply with quote
Back to top
 Alert Moderators
RealPolitik
from United Kingdom
PostPosted: Mon Mar 14, 2011 8:08 pm Reply with quote
Thanks for the responses. I couldn't easily slip them under the architrave as there's a slight slope across the threshold.
I have a lot of fine grit stuck in my eyes but managed it after a bit of patience with the wet cutter. I've used 7 mm spacers on these bigger tiles, so a 5 mm gap around the skirtings and so on doesn't look too out of place.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1088 times
PostPosted: Mon Mar 14, 2011 8:46 pm Reply with quote
"Are you afraid of the dark?
Always wear your safety goggles!"
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling All times are GMT
Page 1 of 1
Jump to:
Jigsaw or Angle grinder to cut tiles? 11 360 Tue May 10, 2011 11:59 am
Cutting travertine...argh. Marcrist blades or a radial saw? 5 820 Sat Apr 11, 2009 6:04 pm
Lifting a porcelain tile without damaging heating element 2 1500 Sat Dec 04, 2010 5:34 pm
Help with choice of Porcelain tile cutter? 10 1120 Wed May 13, 2009 2:06 pm
need super drill for drilling porcelain tile 5 860 Wed Dec 31, 2008 4:05 pm
DIYnot
