Gloworm Boiler Pilot Light Wont Light
22 Mar 2011
Hi All
Had a Look around & cant see My excact Problem Posted here....
I have a gloworm Boiler & when i hit the Boost...The Spark beside the Piolet...Just keeps Clicking the Pilot wont Light....... So i took off the Front cover & When i Blow Very Gently where the pilot is...It Lights up & If i keep blowing for around 15...20 seconds...The System Fires Up....
Wondering if anyone Knows what the Problem is?
Opening the combustion chamber is something that should only be done by a gas registered engineer.
Its one of the forum rules that we dont give advice on gas matters other than advising you to call a professional.
Tony
possibly a blocked pilot injector,not enough gas getting to the spark to light.
I Took off the Pilot injecter & the Small silver Pipe Feeding the Gas to the Pilot.....& i used a small Pin...To make sure it wasn't Blocked ...Then i put it back on & Its Kicking in Now....Still clicking about 10 time then Lighting...
It would seam this was the Problem.. :D :confused:
Spot on grahamtheplumber.......Thanks a Lot
