DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking radiator thermostat/valve
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
helpneeded
from United Kingdom
PostPosted: Sun Jun 12, 2005 2:14 pm Reply with quote
One of my radiators leaks when I turn the radiator thermostat off. No leaks once the radiator is heating the room, only when I twist the thermostat to off. Any ideas what is causing this?
It's frustrating because that particular room gets quite hot whilst other rooms need the heat. So the only way I can regulate the heat is to use the main thermostat that controls the boiler!
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 15 times
PostPosted: Sun Jun 12, 2005 10:41 pm Reply with quote
You don't say where the leak comes from. But assuming it is around the little pin sticking out of the valve body, under the head, you might get away with tightening the gland seal (hexagon shape around pin). More likely is that you will need to replace whole thermostatic rad valve.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2527 times
PostPosted: Sun Jun 12, 2005 11:00 pm Reply with quote
You can reduce the heat output from this radiator by turning down the lockshield valve at the other end of the rad.
Ideally close the lockshield conpletely and then open half a turn. Leave for an hour or so and if its not warm enough open a little more.
The lockshield may have a blank cap which needs to be removed and then turn the spindle with a spanner.
Tony Glazier
Back to top
 Alert Moderators
chrishutt
Thanked: 15 times
PostPosted: Sun Jun 12, 2005 11:04 pm Reply with quote
Brilliant lateral thinking Tony. Why didn't I think of that?
Back to top
 Alert Moderators
helpneeded
from United Kingdom
PostPosted: Mon Jun 13, 2005 12:30 am Reply with quote
Thank you Tony and Chrishutt.
Tony, I will try what you suggest and see if that works. Chrishutt, I don't exactly know where the leak is from. The first I knew of it was the stain appearing on the ceiling of the room below. When I checked the offending radiator, the carpet in the vicinity of the leak was wet, but I don't know where on the radiator the water came from. I just didn't know what I should do and have left the radiator on since.
Oh, I didn't mention that the radiator valve had to be at the highest setting in order to prevent leaks. However, I think Tony's suggestion will take care of that.
Thank you both, once again. Your advice is much appreciated.
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1107 times
PostPosted: Mon Jun 13, 2005 8:15 am Reply with quote
Unfortunately Tony's suggestion will not take care of that..
Let the system cool than carefully do the nuts upon the pipe in and out of the radiator valve
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
mira excel thermostat shower leaking on installation help 5 1200 Tue Apr 12, 2005 6:27 pm
New immersion thermostat leaking 9 160 Sat Aug 20, 2011 3:59 pm
Tampered thermostat radiator valve control head 2 180 Sun Dec 12, 2010 2:10 am
Leaking Thermostatic Radiator Valve 9 11720 Sun Jan 06, 2008 12:56 pm
Leaking Cast Iron Radiator Valve 5 200 Thu Apr 28, 2011 8:23 pm
DIYnot
