Just fitted my first Accenta G4. Only a basic system 1 exit door, and 2x PIR. I cannot work out how I need to program the system for the exit door. I assume that this should be a timed circuit, the 2 PIR are listed as used, and non as inhibit.
When I set the alarm, opening the exit door caused a "setting fault: Front Door" to be displayed. a) Is this normal? or should the alarm be wired/programmed differently.
