My combi boiler is working fine fine for central heating but has stopped producing hot water, although it has worked a couple of times then failed again immediately after turning off the tap and re trying. I used the diagnosis flow chart in the manual the standby power light is on but no demand light the water flow seems fine and the chart suggests replacing the flow switch but does not mention this switch in the spare parts or in the diagrams is it the micro switch assembly and how much to replace it? Any advice would be greatly appreciated.
