DIYnot
Local | Network
   DIYnot > Forums
Local | Network
porcelain tile drill bits
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling
Author Message
willbrady7
from United Kingdom
PostPosted: Wed Jun 15, 2011 11:04 am Reply with quote
Any expert/professional tilers here who can advise what make of porcelain drill bit I can buy that wont blunt after 3 holes drilled into solid porcelain tiles? I used the fancy water drip device and didnt drill dry. First bit was 7 from Homebase so I wasnt surprised when it blunted after one hole. Second one was on offer from 19.95 to 9.95, DeWalt from Screwfix online and I was disappointed that it blunted after 2 holes drilled. Any advice gratefully received as dont want to waste more money. Drill bits cost more than the towel rail and toilet roll holder !
Will
Back to top
 Alert Moderators
mypetearthling
from United Kingdom
Thanked: 14 times
PostPosted: Wed Jun 15, 2011 11:07 am Reply with quote
both Marchrist and Rubi are good, but they're both pretty pricey. That's the problem with trying to get through porcelain...
K
Back to top
 Alert Moderators
bbtc
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jun 23, 2011 9:04 am Reply with quote
i find both marcrist and tile right do a wax filled hole cutter, no water required just a drill that has an rpm of thousands, like the old cheap bosch one of the 1980s, start the drill on as fast as possible, hold it at about a 45 degree angle, offer it up to the tile and make the start of your hole, after a few seconds you can straighten up your drill while all the time having the drill on full speed, dont be tempted to stop to have a look as this will stop the wax inside the drill bit working fully.
tile shop say you can get 40 to 50 holes out of one bit, but in reality i only ever get 10 to 15 max
The tile right one is about 20-25 the marcrist one is about 50, but does do a few more
This is why tilers need to know at the quotation point of a job, if there are gonna be any holes to be drilled, it can cost loads for the tiler, and we hate it when it is just slipped in by the customer as your just about to drive away from the job icon_twisted.gif
Back to top
 Alert Moderators
tictic
from United Kingdom
Thanked: 172 times
PostPosted: Thu Jun 23, 2011 5:03 pm Reply with quote
drill 365..think you will see their advert on this site,just click on it.
Back to top
 Alert Moderators
xr4x4
from United Kingdom
Thanked: 268 times
PostPosted: Thu Jun 23, 2011 6:10 pm Reply with quote
i use normal glass and tile drill bits.
start smaller than you need, keep the bit cool by dipping it in water, but the bit wont cut wet.
wibble it about a bit with hard pressure and slowish speed, you will hear it cutting.
Back to top
 Alert Moderators
willbrady7
from United Kingdom
PostPosted: Thu Jun 23, 2011 10:05 pm Reply with quote
Thanks to you all. I think I was pressing too hard - bought the same DeWalt one and was more gentle, still using water dripping slowly from above. 3 more hole done and bit intact. About to do new kitchen and 2 new bathrooms, so all your advice may well come in handy ! Thanks to you all !
Back to top
 Alert Moderators
bathstyle
from United Kingdom
Thanked: 65 times
PostPosted: Fri Jun 24, 2011 10:11 pm Reply with quote
Richon tools
365 Drills or whatever they are called are much more expensive.
Import them directly from Honk Kong yourself via Richon, i have been using them for years.
http://richontools.com/index.php?main_page=index&cPath=1
All currency is in USD but don't worry you can still buy no problem.
Look at the mark up of 365 drills
http://www.365drills.com/
Disgusting prices especially as Diamond coated hole saws aren't too far away from being disposable items.
I remember a few years back the guy from 365 tried selling stuff on a Forum i frequented, I noticed he had some Diamond grinding discs on his site. I recognised them as they were the same ones I bought from Lidl weeks before. Great company!
Back to top
The following user says thank you to bathstyle for this useful post:
willbrady7 (27 Jun 2011)
 Alert Moderators
bathstyle
from United Kingdom
Thanked: 65 times
PostPosted: Fri Jun 24, 2011 10:17 pm Reply with quote
Proper solid Porcelain cannot be touched by the El cheopo spear shaped tile and glass bits, even if you start small and water cool, you would need 4 bits per hole.
Even the marcrist Spear type which cost about 20 a pop struggle with good porc, in fact so do the Armeg.
Back to top
 Alert Moderators
oilboffin
from United Kingdom
Thanked: 36 times
PostPosted: Thu Jun 07, 2012 3:54 pm Reply with quote
I would not use porcelain tiles too hard but some buy them
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling All times are GMT
Page 1 of 1
Jump to:
best drill bits for tiles. 2 400 Fri Oct 17, 2008 5:24 pm
Attaching shower bits to tiles 2 440 Tue Feb 02, 2010 9:21 am
using diamond core bits on slate 6 600 Mon Aug 04, 2008 10:17 am
Drill bit for porcelain tile 7 400 Fri Aug 12, 2011 5:35 pm
need super drill for drilling porcelain tile 5 860 Wed Dec 31, 2008 4:05 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
