In all honesty it'll be fine, The GA3000 insulation has been a stalwart insulation for years. It is very slightly less resistant to heat loss though.
However if you wanna get slightly more technical insulation does not have a U Value. A U-Value is an overall measure of a construction (like a wall or a roof or a floor) as to how resistant it is to loosing heat. The lower the U-Value the better.
Insulation is measured by an R Value which is the thermal resistance of a material that is how resistant is it to the transfer of heat through it. The higher the R-Value the better.
100mm of GA3000 has an R-Value of 4.30 m²K/W.
95mm of GA4000 has an R-Value of 4.30 m²K/W so is equivalent to 100mm of GA3000.
100mm of GA4000 has an R-Value of 4.50 m²K/W.
So the GA3000 series is less resistant to heat transfer. Really pretty insignificant though and its widely believed that this type of insulation looses some of its resistance to heat loss over time anyway (the gas leaks out).
Think of it as the new range is better rather than the old range is worse.
If you want to get all pedantic about it have a go on the Celotex U-Value calculator although you'll need to know the construction and what U-Value you're trying to achieve
http://www.celotex.co.uk/Other-Resources/U-value-Calculator although you may have to login to use it.
ebay can be a good source of insulation.
