Joined: 07 Jul 2005 Posts: 6 Location: Leeds, United Kingdom Thanked: 0 times
Posted: Thu Jul 07, 2005 11:14 pm Post Subject:
connecting plastic to cast iron stack
I have a cast iron soil stack with cast iron branch to wc.I need to replace the branch with 4\\\" 110mm as it is corroding and is only 3\\\" diameter ( problems flushing big waste away) Could you tell me if I can connect a plastic branch into soil stack and if so how and how do I remove the cast iron branch,someone told me to grind the cast iron out and fit the plastic in, then make it good with putty is this correct?
Joined: 24 Jul 2003 Posts: 18663 Location: London, United Kingdom Thanked: 62 times
Posted: Fri Jul 08, 2005 10:14 am Post Subject:
There are a few methods, as k in your nearest decent plumbers merchant. There's a rubber Branch which goes in where your CI one is and has jubilee clips round the 3 pipes. Looks naff though.
It's much neater and not too difficult to replace the whole stackpipe.
Joined: 18 May 2004 Posts: 19149 Location: Tennessee, United States of America Thanked: 400 times
Posted: Fri Jul 08, 2005 10:15 am Post Subject:
Re: connecting plastic to cast iron stack
bit more info might help as in what size is the stack
Posted: Fri Jul 08, 2005 4:36 pm Post Subject:
Hi the main long soil stack is 4" diameter with a 3" tee off to wc this is about 12" long from where it goes into the house, there is a coupling ( I think that is what it is) on this pipe and that is where it is starting to corrode
Posted: Fri Jul 08, 2005 4:50 pm Post Subject:
It'll be cemented onto a conversion piece, at or just below ground level. You wiggle the CI slightly and lift it out, and remove the cement. I've siliconed the plastic in but there's probably something pukka for it.
Joined: 01 Jun 2004 Posts: 891 Location: Cambridgeshire, United Kingdom Thanked: 5 times
Posted: Fri Jul 08, 2005 10:29 pm Post Subject:
doitall wrote:
I would just cut the bad bit out and replace with timesaver cast iron branch and sockets
Im sure someone has mentioned it before, but what is the preferred method to cut cast iron. I've got such a job coming up. I have to install a ground floor loo so need a branch at ground level. Think I may need to go a step further than what Chris suggested and try to chisel out the concrete since I need to be close to ground level for the right drop. 1:40 right?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
