RajivParekh
Joined: 12 Jul 2005 Posts: 2 Location: India Thanked: 0 times
Posted: Tue Jul 12, 2005 10:54 am Post Subject: Clarification for Cement Paint |
I am facing a new type of problem since last few months/year.After Cement Paint is apllied on New Rendering after Proper Surface Preparation,After Monsoons whent the Surface Dries WHITESS Patchy Appreance is observed.When the Same Surface is wetted again,we are not able to see the Patchy appreance.
What i understand is that this is \\\"Calcium Sulphate Salt Formation\\\".
Please Advice me if this can be avoided by adding some additive in the formulation & also if we can remove this formatation with help of some solution.
I will really appreciate the feed back at the earliest.
Regards |
jbonding
Joined: 04 Feb 2005 Posts: 1926 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Tue Jul 12, 2005 5:49 pm Post Subject: |
do a search on efflorescence this might help. |
Zampa
Joined: 14 Mar 2005 Posts: 5727 Location: United Kingdom Thanked: 3 times
Posted: Tue Jul 12, 2005 8:57 pm Post Subject: |
If it is effloresence you will need to re coat of the wall with alkali resisting primer.
Are the patches looking like salty cristals?
What are you meaning by Cement paint?....do you mix it up yourself?..powder/water mix? __________________ How much! |
RajivParekh
Zampa
Posted: Wed Jul 13, 2005 6:07 pm Post Subject: |
ok...forget the idea of the alkali primer...it probably will not take to the cement paint.
The lime in it has a few purposes...one of which is too help prevent mould growth ...and also to keep it white.
You could try cutting it down and replacing some of it with titanium dioxide or another white pigment...its a long shot though.
Im no paint chemist im affraid.....i would suggest you contact the makers or one of the large paint companies over here..
Sorry I cannot help you much more than this.  __________________ How much! |
