Problem with AquaLisa shower
1 Aug 2011
Essex
Hi, new to this forum so bear with me.
I have a shower that is working intermittently, will work (ish) on just hot or just cold but stops when trying to mix (so basically unusable at moment).
I think its an AquaLisa Aquavalve 900 (or similar) and is approximately 10 years old.
I did wonder if its a problem with the cartridge (as this hasnt been changed since new) and found out that you remove the Aqualisa badge on the mixer tap and there should be a screw to remove it. All I found was a black thing with a hole in it and I am no wiser as to how remove.
I can attached some pics in case anyone has any good ideas on how to fix the problem. Any help would be gratefully recieved?
Regards
Chris
Afternoon Chris,
Would you be able to post some photos up and I'll see if we can help you identify your shower please?
Kind Regards,
The Aqualisa Team
