there wouldn't be a problem removing some of the leaves, different people have different views on what works best.
One option is to split each leaf along the centre and just remove half of it, another option is to remove all the leaves below the lowest growing fruit to allow the water to travel further up the plant.
I do both of these depending how the plant is growing, i wouldn't remove more than half the leaves though as they help draw water up the to the fruit.
I take it you are growing them outdoors (not in a heated greenhouse etc).
The fruit ripens with heat, something we are not getting much of this season. If the fruits are large enough, remove them from the plant and put on a windowsill indoors. They will soon ripen.
It is not the purpose of leaves to sap water from the fruit. It is the purpose of leaves to capture energy from the sun allowing the plant and fruit to grow.
