Instant water heater
4 Jul 2005
Hi! :)
I'm going to be fitting a 5.5 kw undersink instant water heater with special low pressure tap, which can be connected directly to the cold water inlet.
Am I right in thinking that a 25amp breaker with 4mm cable will be OK for this?
Ta!
Mary :D :D
XXXX
sounds fine as long as the run isn't unreasonablly long and you aren't burying the cable in insulation.
Blimey!!! That was QUICK!!
You not gotta life Plugwash? :LOL: :LOL: :LOL:
The run will be about 10m..
That OK?
Thanks for the help!
:D
