DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
circuit breaker
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
marliz
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 20, 2005 6:11 pm    Post Subject:
circuit breaker
Reply with quote Thanks
After reading about MCB\\\'s on forum could someone please let me know if the following is an MCB or a \\\'more or less de facto standard for old CU\\\'s\\\'. My electrician wants to alter our boards, but I want to understand what he is doing BEFORE he begins, not after he has been paid. Any help would be greatly appreciated by someone who is always being (rude word)on by workmen.
MK(I know the make is Sentry) LN 59116 s B 16 240V~ 6000 3 Underneath that there is a black switch - up for ON and down for OFF.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
kai
from United Kingdom
Thanked: 5 times
PostPosted: Wed Jul 20, 2005 7:15 pm    Post Subject:
MCB
Based on what you write, it is an MCB with a max breaking capacity of 6ka or "M6" for those older userson the site.
The B16 means a rating or "nominal setting" of 16 amps.
Type B means the fast magnetic trip will operate between 3 to 5 times nominal setting . i,e, 48amps to 80amps for short-circuit protection.
The B16 MCB is most often used to feed a household 3000 watt immersion heater, via some 2.5.sq.mm. cable, and a 13amp switch fuse-connection unit adjacent the hot water cylinder itself as a controller.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Jul 20, 2005 8:14 pm    Post Subject:
Re: circuit breaker
As Kai says, it's an MCB.
But what of it?
Quote:
'more or less de facto standard for old CU's'.
¿que?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
marliz
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 21, 2005 12:36 pm    Post Subject:
MCB
Many thanks for your replies. Now I am sure it is an MCB the electrician cannot tell me I need an MCB and rip me off. Thanks again. marliz.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Jul 21, 2005 12:39 pm    Post Subject:
What are you getting an electrician in to do?
__________________
Back to top
 Alert Moderators
marliz
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 25, 2005 3:06 pm    Post Subject:
Hi, I asked my electrician to put in some downlighter, remove some socket and retain others. Because he know there have been problems in other areas of the house he decided to rip out all cables to start afresh. But now I have had to delay plasterers, tilers and cooker delivery because he is always busy. When I asked if I could have an electric shower in a room where floorboards are already up, he said he may need to give me a complete new board (or somethin). I just dont want to be taken for a ride. Now that I know it is a fully modern consumer unit I feel in a stronger position to query his decision. He has always been fine with us, but I just dont feel as easy with the situation this time.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Mon Jul 25, 2005 3:25 pm    Post Subject:
Could you post a pic of your consumer unit here please
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Jul 26, 2005 1:31 am    Post Subject:
You may well need (or be better off with) a new board.
If your MK Sentry CU is very old, the mcb's will no longer be manufactured, and to fit new ones requires a conversion kit. Plus, if you need RCD protection (as you surely will) for rings and shower circuits etc.., and don't have it already.....
Plus, if you have an RCD but it is 63A rated, then it should be replaced with min. 80A one.
All these reasons point towards a potential CU upgrade.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Circuit breaker rating for cooker circuit? 8 540 Sun Oct 15, 2006 12:37 pm
Tripping Circuit Breaker 10 540 Tue Sep 07, 2004 8:19 pm
MEM TP circuit breaker 2 160 Tue Feb 10, 2009 9:06 pm
Stab Lok 32A circuit breaker 3 220 Sat May 27, 2006 7:24 am
Circuit Breaker (MCB) Keeps Tripping HELP!! 3 440 Mon Sep 20, 2004 5:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
