DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
2.5mm or 4.0mm
This topic originated from the How to page called Converting a radial circuit to ring circuits
Click here to return to the page called Converting a radial circuit to ring circuits.
  View previous topic :: View next topic
Author Message
jabezz
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 28, 2005 10:45 am    Post Subject:
2.5mm or 4.0mm
Reply with quote Thanks
I have three sockets off a 4.0mm radial circuit serving three bedrooms. Can I add an extra socket in each bedroom using 2.5mm cable. (The circuit breaker is 30amp.)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ryanj
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 28, 2005 11:23 am    Post Subject:
No.
Use 4mm^2.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Jul 28, 2005 11:36 am    Post Subject:
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
jabezz
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 28, 2005 11:37 am    Post Subject:
Thanks Ryan J for your quick response. I'll havta buy 4.00mm cable -- I had loads of 2.5mm leftover from a previous (ring main) job.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Jul 28, 2005 11:42 am    Post Subject:
If it had been a 2.5mm˛ ring final, on a 30A breaker, he could have spurred off a socket in each bedroom with a single piece of 2.5mm˛ cable.
As it is a 4mm˛ radial, on a 30A breaker, he cannot add a branch with a single piece of 2.5mm˛.
Discuss.
__________________
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Jul 28, 2005 11:47 am    Post Subject:
ryanj wrote:
No.
Use 4mm^2.
Alternatively, yes if you use 2 x 2.5mm˛ of the same length.
__________________
Back to top
 Alert Moderators
jabezz
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 28, 2005 11:48 am    Post Subject:
Link has too much
Hi Ban-all-sheds -- thanks for the link in response to my question about 2.5mm or 4.00mm cable -- however this link has a lot of info -- which particular thing should I be looking at?
ban-all-sheds wrote:
http://www.diynot.com/forums/viewtopic.php?p=81696#81696
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Jul 28, 2005 12:19 pm    Post Subject:
That link should take you straight to the reference post called SIZING MCBs & CABLES - that's the one to read regarding this question....
__________________
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 28, 2005 3:54 pm    Post Subject:
Discuss.
because on the radial, you can continue to add more sockets to the extra socket, so 2.5 would overheat. where as on a ring main, your only susposed to take 1 spur which should not exceed 13A so 2.5 is OK
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Jul 29, 2005 12:52 pm    Post Subject:
10/10
__________________
Back to top
 Alert Moderators
jabezz
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 29, 2005 2:17 pm    Post Subject:
THANKS!
Greatly appreciate each one who posted replies. I not only know what to do, but also the WHY!
It so much more reassuring to learn the reason behind a standard, knowing it's not just some arbitrary rule.
Thanks!
Back to top
 Alert Moderators
streethawk
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 7:40 pm    Post Subject:
ryanj wrote:
No.
Use 4mm^2.
but i can't get 4mm anywhere anymore... what am i meant to use - 6mm? bit excessive, surely!
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Fri Aug 11, 2006 7:55 pm    Post Subject:
Have you tried:
http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Twin_and_Earth/index.html
BTW the post you are replying to is over 12months old.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 10:49 pm    Post Subject:
jabezz, if you are only feeding a few bedroom sockets and you have central heating i imagine the load will be quite low so you could run 2.5mm radials and lower the amp rating of the mcb to 20A. but if you had an overload problem later this could be a pain. if you can get back to the fuse board you could change this circuit to a 32A ring using the 4mm cable as the first leg of the ring then from the last socket in 4mm round the rest in 2.5 then back to the board.
Back to top
 Alert Moderators
streethawk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 12, 2006 3:57 pm    Post Subject:
Spark123 wrote:
Have you tried:
I hadn't, no just the obvious suspects - wickes, screfix etc.
thanks for that
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
