Hello all, I'll try and be brief
Fortic on 1st floor in bathroom, Boiler in kitchen beneath (Glow Worm space saver)
Moved in to house needed space in bathroom for shower so changed old Fortic to conventional vented cylinder with header tank and put whole lot in loft.
Changed old system which was a bit odd:
thermostatic valve with motorised on off (controlled by old mechanical controls) on primary coil with bypass controlled by gate valves. pumped CH/gravityHW
to:
DRandall contractor pack, ie: wiring centre, 3port, tank stat, room stat, controls.
The HW circuit works absolutely fine, but when I switch to CH the boiler cuts out after 15 mins, leaving the pump circulating pointlessly. When I say cuts out I mean it just stops burning, not complete cutout with no pilot. I don't need to reset it in any way, it just stops burning.
Only unusual thing about set up is that I have no room stat, but I have made the neccessary mod to the wiring centre to allow for this..
whats my next course of action?
thanks...
to:
thanks...
