DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
running services with floating floors
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
trevorga
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 04, 2005 5:05 pm    Post Subject:
Reply with quote Thanks
Does anyone have any suggestions where to run pipes and cables when I can not do so under the floor/above ceiling which is an insulated floating floor system which once down will stay down forever?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
pdcelec
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 04, 2005 5:14 pm    Post Subject:
run them on the surfaces above the floor
Back to top
 Alert Moderators
trevorga
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 05, 2005 7:32 am    Post Subject:
running services above floor
Thank for this. I assume it is permissible to run cabels channeled into the plaster or behind the skirting? Does any know of any propriety systems for running behind skiting boards?
Thank you
Back to top
 Alert Moderators
Qedelec
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 05, 2005 12:11 pm    Post Subject:
There are a number of skirting trunking manufacturers out there. Some are even made to match your decor.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Aug 05, 2005 5:31 pm    Post Subject:
None of which, of course, comply with Part M...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Aug 05, 2005 5:37 pm    Post Subject:
just run all your chases in L shaped routes between points that way you are in permitted routes the whole way
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Underground services 2 300 Tue Nov 21, 2006 10:23 am
Services In Same Trench 9 500 Tue Mar 20, 2007 6:54 pm
On-Site Calibration Services 10 660 Sun Oct 26, 2008 8:09 pm
Floating earth wire is live 6 2100 Thu Sep 30, 2004 10:57 am
floating switch 4 200 Tue Oct 26, 2004 8:41 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
