DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
extending a mains cable
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
  View previous topic :: View next topic
Author Message
kumbi
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 04, 2003 12:48 pm    Post Subject:
Reply with quote Thanks
I have a ring circuit at home and I wish to move the current socket to a further location. can I extend the two 2.5mm cables that are in the current socket, using a 30Amp Junction box?
Is it good practice to extend 2.5mm cables and above using junction boxes.
thanks
kumbi
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Aug 04, 2003 5:08 pm    Post Subject:
yes you can move it provided you use 2.5mm cable and one junction box for each cable.
Officially you are now supposed to use crimps, but i personally think these un reliable, unless you are expearianced with them and have a proper ratchet crimper
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
kumbi
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 08, 2003 9:47 am    Post Subject:
Extending a mains cable using 30amp terminal Block Connector
Thank you breezer for the reply, I will sleep better at night now. One more question please, the same question as before but this time using 2 x 30amp Terminal Block connectors to extend the two 2.5mm cables. The Terminal blocks and the cables will be set inside a wall that i will skim over and then tile over.
Please help again.....
(Phew! what a heat wave we have in London.)
Regards
Kumbi
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Aug 08, 2003 5:20 pm    Post Subject:
in short NO, do as you did before, but can you not lift a floor board an pull the origonal cables out?
today you know they are there, what happens next year?
electricity has no prejudices it kills any one
(and yes i know about the heatwave in London, just come back)
__________________
Forum = Opinions
Back to top
 Alert Moderators
kumbi
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 09, 2003 7:24 pm    Post Subject:
Thanks Breezer I ended up using junction boxes as you advised, I have seen the expert advice you have given in other subjects, thank you i'ts good to know there is some out there who does know what he is doing... have a good day.
regards
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Aug 09, 2003 7:50 pm    Post Subject:
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Extending ring mains, cable sizes,voltage drops etc 2 500 Wed Feb 16, 2005 4:47 pm
Extending a mains socket cable 30 1380 Wed Feb 27, 2008 8:47 pm
Extending Mains Ring 5 460 Fri Apr 01, 2005 5:41 pm
New CU and extending 13amp ring mains with mixed colours 4 280 Wed Jul 30, 2008 7:04 am
Extending mains ring 6 680 Wed Apr 27, 2005 2:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
