zanussi FJS 1425 W
Status
Not open for further replies.
8 Sep 2005
Devon
Machine seems to be stuck in drain mode. after turning machine on and selecting cycle(any cycle)the machine switches on drain pump and drain machines and stops with start light flashing.Drain pump operates ok as i filled machine up manually and it is pumping fine. Any ideas?
Possibly a blocked water level pressure vessel, causing the machine to think it is full of water. There will be one or more pressure switches mounted toward the top of the machine. If you pull off the rubber tube from such a switch and it makes one or more clicks this will confirm that you have a blocked pressure vessel.
Status
