adriandukesell
Joined: 11 Sep 2005 Posts: 1 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Sun Sep 11, 2005 8:33 pm Post Subject: 72 inch internal doors |
I am looking for anyone who suplies 72 inch internal four panel doors, and also four panel with top panels glazed. Any suggestions would be gratefully recieved. Also should I fail to find any I intend to find a 78 inch door with a deep bottom rail and remove 2 inches from the top and four from the bottom, then glue dowells through the tennons on each side of the bottom rail,can anyone tell me if this would be the correct way to strengthen the door. |
TexMex
Joined: 08 Jul 2004 Posts: 1523 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Tue Sep 13, 2005 8:35 am Post Subject: |
I'd suggest that removing that amount of material from the door, would not only weeken it, but probably also spoil the aesthetics of the whole thing. If you were doing this to make use of some cheep doors you had knocking about, for something like a workshop then I'd understand. But to pay going rate and then have all the agro to end up with this result wouldn't be ideal.
Have you tried any of your local joiners. They can probably make the doors to measure. You may be surprised how reasonable their prices are. Have a look here (insert your own postcode). |
big-all
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Tue Sep 13, 2005 9:41 am Post Subject: |
heeelllooo and welcome
i pretty much echo the sentiment of tex mex
you will find modern mass produced doors do not have mortice and tennons the styles and rails are simply held together by gluing the moulded shapes together
look on the top of any mass produced door and the join line you see is all that supports the door
i would not remove more than about an inch "total" from any door because it will not only look poooo it will greatly weaken the structure __________________ big all
we are------------------ all still learning |
wedge69
Joined: 14 Jun 2005 Posts: 209 Location: Worcestershire, United Kingdom Thanked: 0 times
Posted: Tue Sep 13, 2005 10:22 am Post Subject: |
72' is a "standard" imperial height for doors. Try Jewsons, they are usually pretty good.
_____________________
moderator
post locked to prevent hi jacking |
