We've got a conservatory which is half fully brciked and then the other half is bottom half brick top half windows. It has a polycarbonate "lean to" roof which a 10o (approx) pitch. It has lead on the house wall over the polycarbonate. The roof is pretty flat with two small raised coverings where the poly sheets meet, they are supported by 2 beams. the size is approx 2.8mlong x 3.2mwide,
Wife wants ME to cover the roof with felt.
I thought that perhaps I Could use rolls to length ways across the roof, they could be overlapped with the top length going under the leading. I can fasten them down at each end of the roof by removing the plastic coving and screwing into the existing "batons" and then replacing the coving. I can also fasten it at the bottom OK.
I'm not sure how to fasten it on the overlaps as I believe strong winds could get under and start lifting/ripping it, is there some sort of cold gluing agent I could use.
Any help appreciated and feel free to blow my plans out of the water.
